Ensure that the following conditions are all satisfied, before you enable IPSG on a port. Otherwise, the system displays error messages.
                    DHCP Snooping is enabled globally.
                    The port is a member of a VLAN that is configured with both DHCP Snooping and IPv6 Neighbor Discovery inspection.
                    The port is an untrusted port enabled with both DHCP Snooping and IPv6 Neighbor Discovery inspection.
                    The port has enough resources allocated to support the maximum number of 10 IP addresses allowed for IPSG.
Enable IPSG to add a higher level of security to a desired port, by preventing IP spoofing. When you enable IPSG on an interface, filters are automatically installed for the IPv6 addresses that are already learned on that interface.
- Select IPv6.
- Select the Source Guard tab.
- Double-click InterfaceState .
- Select a value:true or false.
- Double-click MaxAddr.
- Enter the maximum number of IPv6 addresses that are allowed to transmit data on the port.
- Optional: To clear the overflow counters, double-click ClearOverflowCount, and then select true.
- Select Apply to save your changes.
- Select Refresh to update the Source Guard tab.
Source Guard Field Descriptions
Use the data in the following table to use the Source Guard tab.
| Name | Description |
| IfIndex | Specifies a value that uniquely identifies the port. |
| InterfaceState | Specifies the state of the interface. The default value is false. |
| MaxAddr | Specifies the maximum number of IPv6 addresses allowed to transmit data through the port. The default value is 4. Note:
                             To reset the value to default, IPSG must first be disabled on the interface. |
| OverflowCount | Specifies the number of IPv6 addresses for which filters are not added on the IPSG port, due to a lack of filter resources. The default value is 0. |
| ClearOverflowCount | Specifies whether the overflow counter must be cleared. By default, the value is false. |
